Sharp AR-M350
  • Tech2002
    • Aug 2008
    • 334
    Sharp AR-M350
    Have a machine where the PM Cycle comes up at 50k rather than 100k. Went into settings to change the numbers but it would not take. Any suggestions?
    • 23008
    '0' or '4'?
    I am assuming that you're in simulation 21-1. Does it revert back to '2' after you exit simulation? Which are you setting it to, '0' for the default or '4' for 100k? Typically these machines come from the factory set to '0' for the default = 100k. If the '4' setting is not holding, try '0' or vice versa. =^..^=
    • AlexP
      Hi
      The first AR-M350 that came out the default PM was at 50k. You need to get the latest firmware to change it to 100k.
