MX 4500N Firmware
  • walt
    • May 2015
    • 15
    MX 4500N Firmware
    I have 2 machines whose memory have been cleardand now its showing improper catridge. Please some one help me whith this machines firmware. Thanks in advance.
  • igi
    • 1507
    Re: MX 4500N Firmware
    firmware is country dependant
    • walt
      • May 2015
      • 15
      English version will do, am from Nigeria.
      • igi
        • 1507
        your copier and toner need to be set?belong
        to the same destination.
        firmware will not help
        • walt
          • May 2015
          • 15
          Thanks for your reply Igi, how do i do that. both machines were working well before its memory was cleared and since then its been showing improper cartridge, but the cartridge works well in another machine.
          • igi
            • 1507
            simulation 26 is your friend. And a manual
            • walt
              • May 2015
              • 15
              I have done tha severally but the problem still persist. Rigth now what I have not done is updating the firmware. Can you help me with one if u have? Thanks Igi
              • faxman28
                • 435
                Did you try a brand new oem toner cartridges ? had this happen , would show improper cartridge in one machine and would work in another, but when I put brand new cartridge in problem machine , recognized cartridge. Some problem with data in copier and data on toner cart chip.
                Also if you reset memory by using secret sim mode, Sims 70 and above, you will have to have eeprom from pcu and mfp board reprogrammed or replace the boards and use eeproms that come on new boards, but that may not work if copier checks s/n on each board.
                I did this once , had machine that was having strange issues and as with certain other manufactures machines doing a complete reset may cure problems, well found out on sharps that when you do this using secret sim mode you can wipe out everthing. luckily machine was small mfp with only one board and eeprom ,but serial number was different and page count was off, but had to use eeprom that came with new board to be able to recognize toner cart.
                • walt
                  • May 2015
                  • 15
                  Thanks for your contribution Faxman28. That is what really happened, but then how do i reprogramme the eeprom. getting another board or the eeprom from a new board has been a challenge.
                  • copyguy1
                    • Jul 2011
                    • 142
                    EEPROM has to be done by sharp. You will need Hot Line case, And atleast the invoice from when it was purchased from sharp.
                    • walt
                      • May 2015
                      • 15
                      Thanks for your post Copyguy1, that is my problem, i dont have all that. updating the fiemware also could help, but i dont have the firmware for this series. can you help me with one if u have
                      • walt
                        • May 2015
                        • 15
                        Thank for your post CopyGuy1, that is my problem, i dont have all that. updating the fiemware also could help, but i dont have the firmware for this series. can you help me with one if u have.
