Sharp AL-1655CS
  • prntrfxr
    • 1622
    [Error Code] Sharp AL-1655CS
    A tech buddy of mine has a problem with a Sharp AL-1655CS. I am not familiar with Sharps. The display for some reason says "UPGRADE SERVER" on the display (He does not know if it was another tech at his company that did something to display the message or if it was something that happened on it's own.) It will not permit him to get in any menus. Is there a way to reset the machine or does this require an firmware upgrade to move forward? Is there any way to return the machine to it's former condition?
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
  • lenovos
    • Oct 2012
    • 140
    Re: Sharp AL-1655CS
    Check the model # I don't think that an AL1655 can display a message other than an error code or number of copies.
      • 23008
      Re: Sharp AL-1655CS
      Lack of connection to the network might produce this message, but it would not prevent access to the service mode. =^..^=
      • prntrfxr
        • 1622
        Re: Sharp AL-1655CS
        Thanks guys. I will let him know.
