Good day,
Gentlemen, I install yesterday a Sharp DX-C200P. There is no problem in copying using ADF, I test multiple copies without any issue. But if we scan a document thru PC using presto, It doesn't pick up the paper in the ADF. The odd thing is, the scanner will move forward as if I scan to the table glass. I try it a couple of times without any luck, but if i open the ADF cover sometimes it will start scanning to the ADF. I Check the scanner setting on the ADF it is enable. Any recommendation is highly appreciated. Thanks in advance...
