Sharp DX-C200P
  • Jhonjon
    • Sep 2013
    • 208
    Sharp DX-C200P
    Good day,
    Gentlemen, I install yesterday a Sharp DX-C200P. There is no problem in copying using ADF, I test multiple copies without any issue. But if we scan a document thru PC using presto, It doesn't pick up the paper in the ADF. The odd thing is, the scanner will move forward as if I scan to the table glass. I try it a couple of times without any luck, but if i open the ADF cover sometimes it will start scanning to the ADF. I Check the scanner setting on the ADF it is enable. Any recommendation is highly appreciated. Thanks in advance...
  • ntbann
    • Jan 2012
    • 627
    Re: Sharp DX-C200P
    Isn't presto a canon software? Why not use sharpdesk?
    • Jhonjon
      • Sep 2013
      • 208
      Re: Sharp DX-C200P
      The Presto manager is included in the software/printer installation.
