MX-M450N power
  • usmjake
    • May 2015
    • 31
    [Electrical] MX-M450N power
    okie doke folks, i have a 450 that when power is applied, the machine begins booting up for a few minutes then shuts itself off and begins trying to reboot again. this followed a paper jam issue. i have no clue where to begin. we've tried unplugging the machine from the outlet and letting it sit for a few minutes but it continues "cycling". any ideas???? thanks guys.
  • copyguy1
    • Jul 2011
    • 142
    Re: MX-M450N power
    One thing is it could be a bad print job. Unplug network cable and see if it stops. If so delete all jobs from the server and print que. I have also seen the MFP pwb cause this issue. Good luck
    • usmjake
      • May 2015
      • 31
      Re: MX-M450N power
      cool, thanks
      • ntbann
        • Jan 2012
        • 626
        Re: MX-M450N power
        Just had a bad print job cause this this week. Its usually something printed from the internet.
        • EasyRider
          • Jan 2015
          • 87
          Re: MX-M450N power
          We have seen a lot of those do that with a corrupt print job being the culprit.
          Usually just a simple site on the internet.
          Like stated above, unplug network cable, reboot copier. If all is well, remove all print ques on all PC's.
          Don't forget to plug that network cable back in!
          ymmv.
          • usmjake
            • May 2015
            • 31
            Re: MX-M450N power
            once again, yall are amazing. we unplugged the network cable and restarted the machine without a hitch. i had them delete the job queues and voila, it worked like a charm. whatever yall are making, yall need a raise. thanks guys!!!!
