sharp al1651cs error e7-11
  • garrycmsi
    • Jun 2015
    • 22
    [Error Code] sharp al1651cs error e7-11
    i have cleaned the optics and lamps,code will come back after several lamp check cycles ant ideas?
    • 23008
    Re: sharp al1651cs error e7-11
    Is the lamp lighting when it codes out? If no, replace light source #1 (the whole moving part of the scanner). =^..^=
