DXC 400 with l4-16 code
  • nmfaxman
    • 1702
    Anybody got the fuser parts picture for this beast.
    I need to see where the press roller sensor flag sits.
    Don't want to replace the whole fuser.
    It turns fine, but there is a thumping noise as it rotates.
    I assume it is the pressure roller not finding home.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: DXC 400 with l4-16 code
    Not your model, but it is probably pretty close (item 16 is your flag sensor lever).
    Hope you have better eyesight than me.
    • nmfaxman
      • 1702
      Found the sensor flag, but it is the cam gear under it that is broken.
      Does anyone have that part #?
      Why replace a fuser for $250 when a $15 part will fix it.
      Machine only has 16k on it.
        • 22995
        Is this what you want?:
        Sharp MX-C311 Pressure Release Detect Plate, Genuine (M5723)
        • nmfaxman
          • 1702
          Guy @ Precision emailed me the fuser parts list.
          Looks the same, but called a gear and is black.
          $12.00, cheaper than $250 for a whole new fuser.
          Now have customer for life.
          Thanks for the quick replies.
          • nmfaxman
            • 1702
            This was the one. Doesn't show in parts guide.
