MX-6240, 7040 (Polaris) with error code C1-0X (various charger cleaner trouble)
  • ben@km
    • Sep 2014
    • 34
    [Error Code] MX-6240, 7040 (Polaris) with error code C1-0X (various charger cleaner trouble)
    Hello Folks out there, is there a way to disable the corona cleaning function when you have an error C1-03,05,07. I need to order parts and want to resume printing for my client in the meantime.
  • rstarr
    • Aug 2011
    • 9
    Re: MX-6240, 7040 (Polaris) with error code C1-0X (various charger cleaner trouble)
    Grease the screw shaft that will work for a time good luck
    • ben@km
      • Sep 2014
      • 34
      Thanks for the tip. I'm hoping for a softsw to disable the cleaner
        • 23009
        This advice comes from one of our long time benefactors:
        Can you please drop some advice for Ben@KM regarding the polaris MC cleaning.... As long as you have the MC Units produced after April 2014 (as-per production run sticker on the box), its modded to stop C1 codes. The only other thing is making sure the CMYK process unit front & rear seal mods are also fitted to stop toner spray falling onto the MC home position sensor.
        In my personal opinion it's a bad idea to disable the primary charge cleaners. Those scorotrons get dirty, and need the automatic cleaning. =^..^=
        • copyCyber
          • May 2009
          • 6
          Test command 44-28, AO and AP. Having the same difficulty. Done all recommended in the service manual. Sharp area rep on his way...
          • copyguy1
            • Jul 2011
            • 142
            We had one giving the code for cyan. We replaced the the Home position sensor located in the back on main drive. Once we got it out we found it had gotten the clear grease in it from the gears.
            Must have been to much put on at the factory. The part number is the same as one that sharp has had a big problem with.
            • repn1999
              • May 2010
              • 310
              are you using the newer MX-750MK or the older MX-620MK when doing pm? this was partially addressed in the switch to 750mk due to cleaner warping. im not aware it can be disabled nor would i recommend it. I would recommend replacing with 750mk and see if that resolves.
              • copyCyber
                • May 2009
                • 6
                Final fix was to replace the AC Monitor PWB and the Program SATA.
