L4 -11
  • HLW
    • Jul 2025
    [Error Code] L4 -11
    Sharp AR250
    L4-1 &L4-10 are the only errors that show in the manual. The problem indicated in the manual would seem to be a main motor problem. Have tried sim25-1 and mail motor checks ok. On the off chance it was a mirror problem I did sim 1-1&2. They look good. I am hoping someone out there has a good idea what is going on. I have tried sim 14 to clear, but it just won't clear.
    Last edited by Guest; 07-17-2015, 10:32 PM. Reason: Forgot to mention a corrective measure taken
  • Rooster 65
    Re: L4 -11
    l4 -11 refers to a shift assembly problem on every sharp I have ever worked on. That said, it has been a LONG time since I have seen an AR-250
      • 23006
      Re: L4 -11
      Are you sure about that code? There's an E7-11, F1-11, U2-11, or U5-11, but AFAIK there is no L4-11. If there was an L4-11, it would have to be some kind of a motor code.
      Odds are, it's something else. =^..^=
      • Rooster 65
        Re: L4 -11
        I can't say for sure, as you have observed, there is no listing for that code for that machine. That said, on all other sharp mfp's, that code indicates a shift motor lock.
        • DaisySteiner
          • Jul 2015
          • 7
          # STAR C STAR14COPY/STARTExecuteYES
