AR-5320 main board
  • swagreis
    • Jun 2008
    • 92
    AR-5320 main board
    When i turn on the machine it gives U2 and can not be cancelled by prog.16 and i found IC-18 in main board damaged i change it once and the same happened .
    Anyone can advise that if there is a short circuit in the machine or a motor loaded???
  • 10871087
    • Jan 2005
    • 1143
    Did the same thing happen right away? What does that chip do, what does it turn on/off? That's where I would look.
    • swagreis
      • Jun 2008
      • 92
      A smoke comes from the chip with a something burn smell and when turning on the machine the gives U2 and when cancell prog.16
      U2 comes again
      i tuned it off to exced the damage.
        • 22937
        For starters lets find out the details of the code: U2-??
        What are the remaining two digits of the error code?
