change m toner
  • spokc
    • 35
    change m toner
    m toner isn't empty but crum chip is getting flagged as empty toning system is working when i test it .
    it is an mx 4100
  • drowranger
    • Jul 2015
    • 122
    Re: change m toner
    this can be toner motor related. if the m coverage is low on prints then you have to check the operation of toner motor using sim 10 & the position of the toner motor cover (Parts Guide - Section 41, Item 45) . check both sides of the covers are attached to the main drive unit.
    • spokc
      • 35
      Re: change m toner
      it is an mx 4100
      as noted in original post the toner motor is working ran sim 10 and then 25-1 and numbers did change also toner density is good and prints look correct
      also do not get any codes, thanks
      • faxman28
        • 435
        Re: change m toner
        make sure sim 26-69 wasn't changed, behavior of machine when toner is at near end and toner out. But once the chip on toner cart is giving toner empty , toner cart has to be replaced, (if you have chips ).
        • michaelc
          Field Tech
          • Mar 2011
          • 590
          Re: change m toner
          Are you using genuine sharp toner cartridges? Just to get that awkward question out of the way
          It didn't say that I couldn't do it in the manual.
          • spokc
            • 35
            Re: change m toner
            yes
            • spokc
              • 35
              Re: change m toner
              ok i will check that sim
              meanwhile i have run 50-22 and found lsu skew was ng on all cyan 19 clicks to right magenta 17 clicks to right and yellow was 11 clicks to right after that all skews were good
              so i put in a new magenta and i will see what happens next
