Sharp MX 3100N Smears across page Changed cleaning Blade no help
  • Doug James
    • Jan 2012
    • 935
    I changed the cleaning blade and the drum unit. The test pattern (Couldn't get it to download on Copytechnet) looks great. I was able to attache this blank page which shows what I am dealing with. I am wondering if changing the developer will fix this or I am dealing with contaminated toner.
    Pretty weired.... Any help is so appreciated !!
  • ntbann
    • Jan 2012
    • 627
    Re: Sharp MX 3100N Smears across page Changed cleaning Blade no help
    That looks like the transfer belt blade collapsed. When looking at it close. Its a mix of all of the toners.
    • harleyrider
      • Oct 2011
      • 348
      take primary unit out the streaks are probably on the belt. If so replace primary blade/belt.
      • Doug James
        • Jan 2012
        • 935
        Thanks so much for your reply, So glad you looked at it closer that I did... I ordered the transfer cleaning blade... Can't believe I was scratching my head on that one... been a long day... lol
        • tr210907
          • Jul 2011
          • 40
          Had a similar looking defect on an MX-2600 today. Process unit and Primary Belt were the first things that went through my mind also.. But upon close glance mine ended up being Fuser related... swapped fuser even though both upper and lower rollers showed little visible sign or wear..
