MX 7001N Open tray two and add paper
  • glenbennett
    • May 2015
    • 68
    [Misc] MX 7001N Open tray two and add paper
    Hello
    I am getting a note on the LCD screen to add paper to tray two however I have tray two filled with paper, is there a way I can change or fix this in the settings... Can I disable tray Two???
    Can someone direct me in the service manual to fix this issue?
    Thank You,
    Glen
    Thank You,
    Glen Bennett
  • rainmaker
    • Jul 2011
    • 77
    Re: MX 7001N Open tray two and add paper
    you can disable the tray by going into system setting go to paper tray setting and un ck copy.fax.first I would do test command 15.if this does work you can swap out tray 1 paper lift with tray 2.what happenssometimes the shaft on the lift motor twist.good luck
    • drowranger
      • Jul 2015
      • 122
      first check if any sensors in tray 2 is active in sim 30-2. specially T2PED
      if not this looks like one of the sensors in tray 2 tandom pwb(pg sec72 item 47) is gone. it is located inside frame. You have to remove tandom trays and you will be able to see two boards with 2 sensors. Left hand one is the one needs cheking. you can check it by swapping the tary2 Tandom pwb with tray 1 board and check if you can get the sensors working in sim 30-2. also check the coupling next to the pwb is straight . this coupling can bent by overloading of paper in tandom trays.
      hope this helps
