Toshiba eS355 Fuser frame
  • bayshoreoe
    • Jun 2015
    • 44
    Hi all,
    Customer broke the fuser exit guide off this unit, and also the pin on the fuser frame was broken. I ordered both but recieved the wrong half of the frame. I have the parts breakdown and can't seem to find a part number for the half I need on either of the fuser 1 or fuser 2 diagrams. It shows the picture, but no part number. Is this not spared, or is it located on another breakdown that I am not seeing? The guide part numbur is 6LH55249000 and the wrong half of the fuser I got was 6LH55305100.
    Any information would be greatly appreciated.
    Brian
    • 22999
    Re: Toshiba eS355 Fuser frame
    I think what you're referring to is the duplex inverter guide, which swivels on pins on the exit assembly. I think if you look at the exit assy diagram you'll find what you need. =^..^=
