Toshiba 3540C Cannot Access Firmware Mode (49)
  • adamcopiercali
    • Aug 2012
    • 88
    I am trying to reload the firmware for the HDD and OS but cannot enter the firmware mode (49) , all i get is a F102_1 error. Any ideas?
    • 23006
    Re: Toshiba 3540C Cannot Access Firmware Mode (49)
    Can you get into 3C Mode to format the drive? You'll need to do that first. If you still can't get into 49 mode you may have a bad Logic Board. I had a 4520C that would not go into any of the service modes until I changed the Logic board. After that the installation was routine. =^..^=
    • djbass
      • May 2008
      • 165
      It's more likely to be a dead HDD (or faulty connection), top of my head f102-1 is no connection/can not mount hdd error.
      If this is the case you won't be able to enter 49 mode, possibly not even 3C mode because they both check for a connected hdd on startup
      No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
      • adamcopiercali
        • Aug 2012
        • 88
        Logic board did the trick. Thanks!
          • 23006
          You're welcome. On my machine I had an intermittently failing HDD. When I installed the new drive, I could not get into any of the service modes. When I put the old intermittent drive back in, it still wouldn't enter service modes. It's just disappointing. =^..^=
