Estudio 356Se error C410
  • noobie1
    • Jun 2015
    • 48
    [Error Code] Estudio 356Se error C410
    Does anyone encounter this kind of error C410 in the Toshiba Photocopier machine. Always appear lcd screen. I already reset the counter using 08 then 2002 and clear 0, but still appearing on it? pls kindly help me with this error.
    Thank you in advance.
  • davod.mardani
    • Feb 2015
    • 32
    Re: Estudio 356Se error C410
    Thermostat has been disconnected check it's conectivity.
    Sent from my SM-N900 using Tapatalk
      • 23009
      Congratulations on executing the fuser error clear. Maybe now would be a good time to fix the cause? =^..^=
      • noobie1
        • Jun 2015
        • 48
        i took out the part of fuser set and open, i find the two thermostat inside which being pinned well or screwed, i did not see any loose connection or disconnection of wire in the thermostat. How do i know that thermostat busted or defective? please help what im going to do or best advice about this the problem to solve?
        • noobie1
          • Jun 2015
          • 48
          what is your best advice to resolve this error ? please help me...
          • didi2005
            • May 2011
            • 401
            thermostat can be measure using multi meter... Take out the thermostat, measure the connectivity...Another trick is shake the thermostat, u can hear sound, if no sound, keep throw on the floor until u can hear the sound...
            So far I never encountered thermostat problem on this model...
            Check also the thermistor, make sure is not dirty...
            And heater lamp, make sure is not burn...
            And the harness, connected properly, wiring not not exposed out due to insulator peel off that can cause "shorting" to the frame...
            • davod.mardani
              • Feb 2015
              • 32
              Test the thermostat conectivity with multimeter. If the thermostat was discontinued insert it into freezer for few hours and check it again!
              • noobie1
                • Jun 2015
                • 48
                Thank you very much for the information that you give to me.It solve my problem.
