Toshiba es4540c erasing any print that is in color when printing b/w
  • Valintine
    • Jan 2012
    • 147
    Hi I have a customer that has a Toshiba es4540c copier that when they send a print job in b/w anything that is in color is erased instead of being printed at a lighter shade. Any thoughts would be appreciated.
    • 23009
    Re: Toshiba es4540c erasing any print that is in color when printing b/w
    That image is probably not erased. It's probably just printed in an image quality that does not display halftones well. I would take a look at the quality settings in the driver.
    • NeoMatrix
      Senior Tech.
      • 3513
      Can you post the original and print out image to the forum ?
      Does the printer driver have a toner-saver/economy print mode ?
      If so, normal black prints will come out printed as a lighter grey shade.
      • sdrawkcab
        Confused & Bewildered
        • Jun 2009
        • 317
        Are they printing from a Mac? If yes they are probably using Black & White in colour settings, Black & White is not Mono, it it Black only and any other colour is ignored, the same as Black and yellow, it will print black and every other colour is yellow.
        Use Mono.
        HTH
        Some days, it's just not worth chewing through the restraints
