Print out is not good in Toshiba 356Se
  • noobie1
    • Jun 2015
    • 48
    I need some advice about this issue about the print out quality, what i need to do or check in the machine?Please see the printout
    Please help me.
    • 23009
    Re: Print out is not good in Toshiba 356Se
    I think I would do a 9S-103 maintenance part printout. I think you'll find that the drum is overdue, and most likely the developer kit too. =^..^=
    • davod.mardani
      • Feb 2015
      • 32
      Is because of main charger has leakage.
      Sent from my SM-N900 using Tapatalk
      • noobie1
        • Jun 2015
        • 48
        i followed your this maintenance this is was printed out. What does it mean about this printout from the machine. please help
          • 23009
          [ATTACH=CONFIG]30485[/ATTACH]
          Wow! I'm going to need new glasses. I can't read a word of it. Can you read this document from the link? =^..^=
          • noobie1
            • Jun 2015
            • 48
            im very sorry the image is not clear. Please try check this another image posted
            please help.
            • didi2005
              • May 2011
              • 401
              Clearly that drum, drum blade, recovery blade & developer need to be change...
                • 23009
                Do you see all those items with asterisks next to them? Those items are nearly twice the desired yield. That's a good place to start right there. =^..^=
                • Sriyanjan
                  • Apr 2015
                  • 79
                  Is this A4 or A4-R
                  Sent from my HTC Desire 820s dual sim using Tapatalk
                  • noobie1
                    • Jun 2015
                    • 48
                    Originally posted by Sriyanjan
                    Is this A4 or A4-R
                    Yes,A4-R
