Toshiba E901/1101 Fuser drive?
  • tech07
    • Aug 2008
    • 410
    I really hope someone's seen this. I am getting JAM 21 on a couple of E901's. It's gotta be in the fuser/exit area. The copier will make a "gear slipping sound" but not loud. The fuser will stop turning (maybe the exit section too, I can't tell) and the jam occurs. Sometimes I can simply lift out the fuser, reseat it, and it will start working. Sometimes I can push in on the fuser by hand during warmup initialization and it will start working. I just can't spot the culprit. Some times It will just start working by itself for several days...Anyone? It's not a BROKEN gear. It's seems like somethingis slipping, maybe a one way?
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    The drive gear (rear frame) for the fuser unit is spring loaded, the shaft gets all gunked up and it sticks. Reach in and you can feel this, clean and lube will fix it for you.
    • tech07
      • Aug 2008
      • 410
      That was it....thanks big time
