Heater Lamp in Toshiba E-studio 305
  • noobie1
    • Jun 2015
    • 48
    [Misc] Heater Lamp in Toshiba E-studio 305
    Could somebody tell me and help me to solve this problem about the Heater Lamp in Toshiba E-studio 305,it getting light on every 5s. Is this a normal or not? I examine one of the Toshiba E-studio 356se machine its not getting light on every 5s? What should i do to fix this issue? Pls. help.
    • 22930
    Re: Heater Lamp in Toshiba E-studio 305
    How often the lamp comes on is going to vary based on a lot of different parameters:
    1) What fuser temperature is set?
    2) What media type is selected?
    3) What media size is selected?
    4) Environmental temperature?
    5) Idling or printing?
    It's safe to say that if the thermostat is not blowing, it's not exceeding the maximum temperature. If you really want to know what the temperature of the roller is, buy yourself a nice infrared temperature probe. They don't cost much, and will tell you exactly what the temperature is without physical contact.
    Infrared Non-Contact Thermometers
    That all being said, you haven't been very specific as to what exact "heater lamp problem" you have. Maybe you would like to elaborate a little on that? =^..^=
    • Riyadh hossain
      I think your copier is OK, its the problem of your over qurisity .
      • didi2005
        • May 2011
        • 401
        If not mistaken, e305 only got 2 heater lamps whereby e356/456 got 3 heater lamps...
