es 556 time for pm fuser web
  • cpjim
    • May 2015
    • 47
    we have one of these that will not reset, using all the known reset procedures. also the fuse web out sensor is working properly.
    I've pm'ed at least a hundred of these with no problems after a reset, any ideas? thanks--jim
    • 22999
    Re: es 556 time for pm fuser web
    Print off the 9S-103 pm parts report or view the values in 6S-2. As you probably already know, most Toshibas track both copy count and motor rotations. Pay special attention to the stated PM cycle for the web count and web motor rotations. You might find one of these is set to zero. Zero maintenance cycle means the light is on all the time.
    You'll find the setting for PM cycle in 08 mode. And I don't know how it gets to zero but occasionally, somehow it does.
    Also, I've seen the web photointerrupter fail, after baking in the fuser for a while. =^..^=
    • cpjim
      • May 2015
      • 47
      I think I checked all that, but i'll try again. thanks for the response.
