toshiba 4520c pm code0700
  • Fattdaddy
    • Aug 2012
    • 38
    Can not find what counter this is from. All pm items below exchange count.
  • gliderider
    • May 2015
    • 131
    Re: toshiba 4520c pm code0700
    Hi:
    0700 is not a valid pm code. 0070 would be. This would indicate that developer is needed for cyan, magenta and yellow.
    • Fattdaddy
      • Aug 2012
      • 38
      Thanks Your code is the correct one. As I said the counts on the pm list are below exchange numbers. Is there a count to reset or does it occur when you set up new developer?
      • gliderider
        • May 2015
        • 131
        Hi:
        It depends on what caused the PM message to trigger. You should look at the PM support page and check Drive Counts versus PM Counts. If the copier is set to trigger the PM message at Drive Counts or PM Counts. One of them is most likely over. If any of these 08 codes are set to 0 then the copier is set to Drive Counts Where a setting of one is for PM counts. 08-223 5578 5579 5580 5581 5582 5583 5584 5585.
        Andrew
        • Fattdaddy
          • Aug 2012
          • 38
          Thanks gliderider That cleared it.
            • 23009
            If you were to print off the 9S-103 maintenance report, you could compare the usage versus pages, and usage versus rotations. I think that you find that one of those cycles (pages or rotations) is not at the desired value. I don't know how those values can change, but they do. It has preceded a NVRAM failure on a couple of occasions. =^..^=
