es 452 SRAM error
  • Riyadh hossain
    • Aug 2025
    es 452 SRAM error
    hlo everyone, recently I faced a problem in es 452.After starting copier first time button and touch does not work then I enter 0+8 mode it show "SRAM ERROR DO YOU WANT TO INITIALIZE IT" then I initialize it then copier works well, if it shut down for an hour same problem occur
    steps taken
    update firmware
    change panel board
    any kind of help must be appreciate
    • 23010
    Re: es 452 SRAM error
    Have you thought about replacing the SRAM? =^..^=
    • Riyadh hossain
      Yes already changed sram but nothing helpful
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        I do not have access to Toshiba anymore. There was a bulletin about loading an early level of firmware then initialize the sram then bring the machine up to current firmware in steps. I have only done this once and it worked for me. I do not remember which version of firmware you start with but I would start around v300 and go up.
        • Riyadh hossain
          yea problem solved by the suggestion of Mr Spock
          thanks to everyone
          • buuluu
            • Apr 2014
            • 49
            Hi Riyadh
            You try to replace another Batery supply power for SRAM IC
            • emujo
              • Jun 2009
              • 3009
              Love the suggestions after the problem is solved...Emujo
              • Riyadh hossain
                In 0+8 mode 995 code and a blue jumper in sys board near bat are important to remove "sram error"
                There are some firmware update , if u update that firmware you do not need 0+8>995
                thanks to all
