Lock 08/05 mode
  • Riyadh hossain
    • Jul 2025
    Lock 08/05 mode
    Have any code to lock only 08 and 05 mode in es452 ? some customer try to cheat about due money,
    • 23007
    Re: Lock 08/05 mode
    I've never needed to, but you can change the default service password (blank) to something else. You'll have to look in the manual to figure it out.
    edit: Oops! I didn't notice the model. More modern machines can set the service password. I don't know about the eS452.
    • didi2005
      • May 2011
      • 401
      Re: Lock 08/05 mode
      Is able to change admin password, but can be reset/retrieve using 08 mode as well...
      I'm curios how customer able to cheat the meter counter, by resetting the counter?
      • Riyadh hossain
        Re: Lock 08/05 mode
        Counter can be reset in 08 mode. Other wise by replaceing sram meter counter can be changed
        , now a day customer have become very clever than technician, u will be astonished to know that they not only use service handbook ,they also use copytechnet .thank you
        • didi2005
          • May 2011
          • 401
          Re: Lock 08/05 mode
          But the counter is accumulated, if reset counter can be easily detected...
          Perhaps u can try enable counter notification to send u counter everyday~~~
          • ZOOTECH
            Senior member of CRS
            • 3375
            Re: Lock 08/05 mode
            THAT is why we don't give out special passwords on a public forum (but it is apparently too late now in your case).
            • Riyadh hossain
              Re: Lock 08/05 mode
              Thanks everyone for response
