estudio 150 "H" error code
  • alliedofficeproducts
    • Jan 2015
    • 92
    Hello all. I have an estudio 150 giving an "H" error code. Is this a fuser error and how do you get into service mode to clear it?
    • 23008
    Re: estudio 150 "H" error code
    Just by looking at the codes you can tell it's a Sharp rebadge. It's definitely a fuser code, but it would really help to know the rest of the code., like H2-00, H3-00, H4-00. The "H" alternates with something ... 2, 3, or 4. To see the rest of the code press the Print key.
    Since it looks so much like the Jaguar you might try the Sharp fuser reset (once you fix the cause):
    To reset: Clear > Auto > Clear > Auto > 14 > Start.
    The Toshiba manual reads slightly different, but I think it means the same thing. Maybe a different batch of translators?
    To reset: Clear → Density select → Clear → Density select → 14 → Start
    It seems hardly worth replacing a fuser on this dinosaur. =^..^=
      • Jan 2015
      • 92
      Thanks. I will check the rest of the error when I arrive on site. The customer only said it was showing the letter H. Have a Merry Christmas!
        • 23008
        The official cross reference is a Sharp AR-153E-N. =^..^=
