Scanning
  • Valintine
    • Jan 2012
    • 147
    Scanning
    Hello
    I have a customer that wants to scan documents using both the feeder and off the glass. They want to scan the tax returns using the feeder and then finish off by scanning smaller documents off the glass and have one file. I have tried to do this but once I start using either the glass or feeder I can not use the other. I have looked through the service manual and have not found a way to do this. Is there a setting that I am missing?
    Thank you in advance.
  • ameritech
    • 96
    Re: Scanning
    Not sure if that is possible. I'm assuming the other documents are to small to use the document feeder. I believe you may have to use adobe professional to merge the two documents as one file.
    • Toshitec
      MFP Engineer
      • May 2011
      • 22
      Re: Scanning
      Its not possible, it keeps asking to feed originals in the same target. Switching flatpanel to RADF vice-versa is not possible.
      • allan
        RTFM!!
        • 5462
        Re: Scanning
        I don't know of any machine that can do this. Do it as per suggestion.
        Whatever
        • emujo
          • Jun 2009
          • 3009
          Re: Scanning
          You are looking for a feature called "separate scan, or job build". Haven't seen a Toshiba in years, but just about every manufacturer offers this. It may be under the editing tab on the control panel. Emujo
          • andyf424
            • Jun 2013
            • 126
            Re: Scanning
            We did it all the time with the separate scan feature on Konica 950's. No that that helps at all, I'm just saying......
              • 23008
              Re: Scanning
              Kyocera calls it Job Build. You can switch back and forth from the glass or DP as many times as you like.
              I have never seen it on a Toshiba. But here is my suggestion: Copy the small originals to LTR, then scan the copies with the rest of the documents into a single document. =^..^=
              • amirj.ptc
                • Jan 2016
                • 11
                Re: Scanning
                Originally posted by Valintine
                Hello
                It cannot be done on Toshiba machine.
                  • 8206
                  Re: Scanning
                  Current model Toshiba copiers can only perform the task you describe via the "Job Build" function found under the Edit tab within the LCD control panel.
                  Unfortunately, Job Build is not available for scan jobs at this time.
                  To perform this task, the customer would have to copy all of the documents via Job Build. Once complete, simply scan all of the printed pages as one file.
                  Blackcat's suggestion to only copy the originals that are smaller than LT size, like receipts, is a good one. You can probably place multiple receipts onto one LT size page.
                  You can also do something creative like create a Template to reduce the # of keystrokes for the customer.
                  On the plus side, think of this as a round about method to force the customer to pay for scans.
