IM2330 firmware
  • copycart
    • May 2009
    • 97
    IM2330 firmware
    I have the firmware for the Toshiba ES202/282. Is it the same as the IM2330, which should cross to the ES233 or 232. I loaded it on a flash drive, inserted in the copier and powered up in 49 service mode. The firmware screen comes up, but it never goes puts the * beside the numbers to be loaded. copycart@sbcglobal.net
    • 23006
    Re: IM2330 firmware
    On the Toshiba you can select or de-select a specific firmware component by pressing an integer on the keypad. If that doesn't work, I would conclude the the Toshy firmware is not compatible with the Oce'. =^..^=
    • riyadh hossainbd
      • Dec 2015
      • 239
      Re: IM2330 firmware
      Firmware are same, I have done this many im copier, just do it . (3+c) then press 3, after complete then (4+9) then start button. After upgrade firmware u have to change printer driver cause your mfp will be toshiba e studio 232/233
