E studio 282
  • tufbnme
    • 493
    E studio 282
    I am strictly a Ricoh guy, a customers neighbor has this Toshiba and it is indicating "time for preventative maintenance"
    They would like to know what is involved and cost. I am going to try and upgrade to a Ricoh but need some info to make the pitch.
    Question is, how do I find out what needs maintenance according to the display if the machine tells. I can get into the admin user tools but didn't see anything about it there.
    • 23007
    Re: E studio 282
    Power up in 9S mode (hold 9 + Start until the green lights illuminate on the panel). The password is typically 'blank' as in no password, then OK.
    Enter 103 then Start. The machine will print off the PM list. Look for items with an asterisk next to them, either by count or by rotations. It's an old machine, but we've still got plenty of them in the field, and parts are still available. Press and hold the power button on the panel to shut down.
    • tufbnme
      • 493
      Re: E studio 282
      Thank you
      • Oystercopy
        • Oct 2009
        • 623
        Re: E studio 282
        Originally posted by tufbnme
        Thank you
        You need the PM Kit and Drum, altogether about $150 dealer cost. This is, by surprise, one of the best Toshibas ever made, and I'm stretching saying that. Most Toshibas I've worked on are junk, but this model was an exception. The only machine in that series that I've ever seen crest 1,000.000 pages. The PM Kit does not include feed rollers, or any of the Fuser stuff (Rollers, Bearings, Fingers), which is a separate Fuser PM Kit with everything but the Bearings. I know you're a Ricoh guy, but I'd take this Toshiba over any Ricoh any day.
        OC
        • jvargas
          • May 2009
          • 44
          Re: E studio 282
