e232 background dirty
  • didi2005
    • May 2011
    • 401
    Top part background dirty when duplex print from PC. Replaced drum, black, developef, performed auto toner adjustment but still the same.
    It only happen on duplex print...try adjusted developer & charger bias, not much different...
    Since is happen on duplex only, is it related to transfer/separation charger?
    What is the default values for all these bias & charger?
    • 22999
    Re: e232 background dirty
    Sorry, I can't see the defect in your photos.
    If the background is through the voids, yes it's charge related. If there's a distinct void, then it's optical. I'll see what I can find about charge settings. =^..^=
    • didi2005
      • May 2011
      • 401
      White background dirty or stripes, visible by eye but not camera..
      Before adjust the settings, i try swap the t/s block n see~~~
      • riyadh hossainbd
        • Dec 2015
        • 239
        [ATTACH=CONFIG]32198[/ATTACH][ATTACH=CONFIG]32198[/ATTACH]
        friend try
        0+8 >491
        >492
        >493
        I think it will be ok
        • didi2005
          • May 2011
          • 401
          Originally posted by riyadh hossainbd
          friend try
          0+8 >491
          >492
          >493
          Checked the value, same like the default value on manual. I've replaced the t/s block unit, performed 10 copies of duplex, no error...Monitoring...
