I am servicing this toshiba e232 which doesn't recongnize cassettes 1 and 2 (LTR and LGL), but it does feed OK from bypass, I already checked with 03 mode to run the lift up motors for cassettes 1 and 2. but no noise nor vibration occurs. / the paper won't lift in either cassette), I already formatted the HD and cleaned and reseated the DIMM also checked wiring and all looks OK, papers sizes are correct. Any ideas are welcomed thanks!
P.S. The machine is used as copier only.
