Trying to set IP takes multiple tries - eBX series
  • arnh79
    • 468
    Anyone else seen lately where if you try and set a static IP on the eBX series machines it won't take it? You change the setting to "static", type in IP, hit apply and the "network initializing" message appears. After a few seconds it disappears and the IP address is back to the one it found when I had it set on "dynamic". This happens almost every time I do a new install, but seems to be more common on eBX1 series (e2540c, e347). I've seen this problem for at least the past year and every new f/w doesn't seem to fix it. Often the only way I can get it to work is to set network card to Static, reboot copier, then type in address I want. Am I alone with this problem?
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
  • didi2005
    • May 2011
    • 401
    Re: Trying to set IP takes multiple tries - eBX series
    Encountered this issue yesterday on e2050c, but the second time I set again is ok...
    Did u try unplug the network cable before perform the IP settings?
      • 23007
      I always assumed that it was my fat fingers. =^..^=
      • arnh79
        • 468
        I never thought of that. Good tip, I'll try it next time I run into the issue.
