No authority to execute the job when faxing
  • Hansen88
    • 1068
    Hello, Customer has a ES 2830 and when trying to fax they are getting the no authority to execute the job message. Does anyone know what this is? Didnt do this before, how to get rid of message. Thanks for any help you can give.
  • arnh79
    • 468
    Re: No authority to execute the job when faxing
    It sounds like they have department codes enabled. You can limit access to various features, including faxing. I think that's the message appears when a feature is disabled.
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
    • Hansen88
      • 1068
      I found the answer using the search. Just had to use the right wording for it to come up. Someone else had this same problem and said it was a bad connection betweent the machine and fax board.
      • arnh79
        • 468
        Thanks for letting us know. Now that you mention it, I ran into that issue once before. Glad you fixed it!
        • Hansen88
          • 1068
          Actually I was trying to help out another tech that was on his way out there. Let him know and he fixed it.
