Print missing from forms on es5560
  • mmtdrk
    • Mar 2014
    • 5
    This machine is leaving text off the page when it prints. Certain forms printed off the internet (payroll stubs) leaves the pay info blank. Four work stations all do the same thing. Another 5560 in a different dept. prints the form fine as does a 5550 just around the corner. Changed drivers, reloaded firmware, cloned from another 5560, reset factory defaults- no change. Still leaves areas blank.
    Any clues where to look next? Toshiba support throughout- they have no clue.
    Thanks!
  • Iowatech
    Not a service manager
    • 3930
    Re: Print missing from forms on es5560
    This is just a wild guess, but make sure the software on the computer producing the print jobs is up to date, or exists.
    Something like this happened to me recently, and I could have sworn I had the latest version of Adobe Acrobat Reader on the computer I was using. But it wasn't there. D'oh.
      • 23008
      Two thoughts:
      1) HTML docs (web pages) can produce some very strange print results. If it's not already a PDF, I'd recommend converting the webpage to a PDF before printing. If there is a print command button nested into the webpage, you may get better results by using it.
      2) Just today I worked on an eS3530C that was producing what looked like a black laser diode failure (blank areas in the main scan direction, intermittently) but for one very strange inconsistency: It only affected certain typestyles!! If there were two or more type styles on a page, only black and only certain specific typestyles vanished. I determined this by examining the dot pattern in the composite black parts of the image. Black only type vanished. Composite black type had black dots in the pattern, even alongside vanishing black only text. The logic board resolved this one, after trying the laser unit. Here's the qualifier: I don't order up a logic board every time I get a quality problem.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        I had the same sort of problem with the "variable" data not printing on a Ricoh machine a few years back.
        Turned out the issue was a setting in their Web browser (I.E.), but I don't remember just what it was.
        • GAF
          • Jun 2016
          • 12
          Ask the end user to use Chrome instead of IE and monitor this. It's more than likely a setting in IE.
          Also if you connect you're laptop to the MFD locally, does it print the reports okay? If so, could be an issue on there network.
          • Logged-on
            • Sep 2010
            • 197
            We were doing a massive setup on the 3055's when they just released new firmware, (2171), within a day of downloading the new firmware, our trainer discovered the calendar available from the samples on Toshiba's website wasn't printing out the words. It turned out when they came out with the new hard drive firmware they somehow damaged the print firmware so if the documents required more then one pass, it would omit the second pass, usually the words. About a month later they released the newest firmware (2173), and that corrected the problem.
            My suggestion is to update the firmware to the most current and that should correct your issue.
            • mmtdrk
              • Mar 2014
              • 5
              A solution was found!
              Toshiba directed the tech to clear values using 08-7300 (Clears adjustment values of all image process 05/08 codes (related to NW print)) and 08-7301 (Clears all the gamma correction table values (related to NW print)).
              Then do a gamma adjustment.
              Problem solved! Thanks for yall your comments.
              mm
