e2500ac f101
  • didi2005
    • May 2011
    • 401
    e2500ac f101
    New ebridge next machine, after few weeks deployed at customer site, call for service f101_13 sign on....this machine no keypad, fully touch screen, how to enter diagnostic mode?
    • 23003
    Re: e2500ac f101
    On any other Toshiba an F101 is a HDD error. It probably says so in the service manual. It also probably tells you how to enter the service mode in the service manual.
    Go ahead and say it: "BUT ITS A NEW MACHINE...!!!"
    Yeah ... well, hard drives fail on both old machines and new machines, especially the wonderful Wipe Drives. I changed one of these drives on an eS357, about 3 weeks after delivery. It hadn't even consumed it's first cartridge of toner yet. Supposedly the latest firmware is supposed to solve some of these early HDD failures, but I haven't seen any evidence of that yet. =^..^=
    • didi2005
      • May 2011
      • 401
      Re: e2500ac f101
      Finally able to read service manual...
      Start FS Menu by pressing the [ON/OFF] button while pushing the [FUNCTION CLEAR] and [START] buttons simultaneously.
      FS Menu: 05, 08, 03, PM Support, List Print, Chart Print
      Start HS Menu by pressing the [ON/OFF] button while pushing the [HOME] and [START] buttons simultaneously.
      HS Menu: Control panel, firmware update, hdd assist...
      The authentication screen require password or like previous model skip only?
        • 23003
        Re: e2500ac f101
        The password will sound familiar: #1048#
        • Aethanite
          Service Technician
          • Oct 2012
          • 42
          Re: e2500ac f101
          Don't get me started on the Toshiba Wipe Drives ..... On average, we are still replacing one a week. And seeing this post doesn't boost my confidence any more lol.
          • didi2005
            • May 2011
            • 401
            Re: e2500ac f101
            This is the trademark of Toshiba, users need to shutdown machine properly...
            • toshibaestudio
              • Jun 2016
              • 116
              Re: e2500ac f101
              PM me if looking for firmware for this new series.
              E2000AC, E2500AC FW: T370HD0W1028
              E2505AC, E3005AC, E3505AC, E4505AC, E5005AC FW: T373HD0W1028
              E2008A, E2508A, E3008A, E3508A, E4508A, E5008A FW: T410HD0W1028
              https://docs.google.com/spreadsheets...it?usp=sharing
              • juliano
                • May 2011
                • 44
                Re: e2500ac f101
                I think you will find that the HDD failure is due to the HDD firmware not "parking" the read head and hence creating bad sectors on the HDD causing failure....latest firmware solves that issue....also fault code can be related to the SATA HDD cable...again an upgraded part is now available
                  • 8177
                  Re: e2500ac f101
                  The SED HDD used in the eBX series copiers were poorly located too close to the copier's fuser section. The SED HDD is an off the shelf Toshiba laptop drive that was never intended to be placed next to a high heat source for long periods of time. The long term exposure to high heat could cause the platters inside the drive to create bad sectors or in extreme cases lose all lubrication inside the drive.
                  The new eBN copiers have relocated the SED HDD far away from the fuser so that there is a low chance of heat transfer.
                  Another problem with the design of the eBX copiers was that many technicians upon setting up the copier would deliberately turn off the third choice Deep Sleep function on the LCD control panel thinking that their customer's would prefer the faster copier response. This meant that the SED HDD has even less chance of cooling down. As you visit eBX copiers in the field, Toshiba recommends that you enable this feature.
                  The new eBN copiers have fixed this problem and to date (knock on wood, only a couple of months) I have not had a SED HDD fail yet.
