Prints three sheets then stops
  • riknight1972
    • Apr 2016
    • 11
    I have a toshiba 3040c that prints 3 sheets and stop to warm up and it continues, I changed the fuser about a week ago but it was doing this for a month before this, is there something I need to reset or what can I do to fix this
    • 23006
    Re: Prints three sheets then stops
    Are there any jam codes or error codes stored in 9S-107? What media type are you using? What media type is designated on the machine? =^..^=
    • didi2005
      • May 2011
      • 401
      Thermopile?
      • Aethanite
        Service Technician
        • Oct 2012
        • 42
        100% Thermopiles.
        We have had quite a few machines start to do this as they get older. Remove the fuser unit, then take off two screws and take the entrance guide off. You will be able to see the two thermopiles. Using a clean cloth, clean the thermopile heads. Try not to touch it as the natural oil in our skin will cause more damage. Reassemble and test.
        Strangely, the majority of machines that do this to us are the higher spec of those series (3540/4540)
        • riknight1972
          • Apr 2016
          • 11
          I just cleaned them and I am testing it now but if I need to replace them where would it be a good place to find parts,Im not a machine tech or have a good supply link of parts.
          • toshibaestudio
            • Jun 2016
            • 116
            Thermopiles normally surface dirty...
            Temporary no stocks for thermopiles in my inventory, but if u really need it, pm me.
            • riknight1972
              • Apr 2016
              • 11
              Originally posted by Aethanite
              100% Thermopiles.
              that worked and thank you for all your help everyone
