Estudio 350 Rattling noise in paper feed...
  • Doug James
    • Jan 2012
    • 935
    [Misc] Estudio 350 Rattling noise in paper feed...
    This machine runs great except for rattling type noise in paper feed gear area. Is there an easy fix for this ? Thanks so much for any help !!!
    • 23010
    Re: Estudio 350 Rattling noise in paper feed...
    Easy fix? Not quick, but easy enough. Machines of this age can rattle because of the clutches, or just because for lack of lubrication in the main drive.
    If you want a 100% success on the first trip, order up the registration, vertical path, and pickup clutches. While you're in there clean and lubricate all the gears and shafts.
    I had a machine like this last week. Lacking the clutches, I cleaned and lubricated the drive. The noise was reduced by about 1/2. That took about 90 minutes, and it would have been exactly the same time if it had included clutches. The only major difference will be how many accessories you have layered over that main drive. It's up to you.
    These clutches can not be disassembled. You can work alcohol into them to loosen them up, but it takes more time and you don't know how successful you'll be. =^..^=
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      clutches or on the lcf feed assembly there is two gears that mesh for the sep roller. If one is missing a tooth it will also cause a rattle type noise.
      • Doug James
        • Jan 2012
        • 935
        THANKS SO MUCH BLACKCAT !!!, figured it was something like that
        • Doug James
          • Jan 2012
          • 935
          THANKS SO MUCH !!! No LCF... Appreciate your feedback !!!
