tosh 556 web advance problems
  • cpjim
    • May 2015
    • 47
    we've got a 556 that advances the web in the test mode but it appears it's not advancing during a typical copy run. I've changed out the fuser unit and has no effect on the problem. has anyone seen this before? thanks in advance
    • 23007
    Re: tosh 556 web advance problems
    I had an eS857 do this about 100K after a PM. The web had not advanced at all, and the fuser didn't look good. While rebuilding it I found this:
    Apparently, one of the pins backed out of the connector during re-assembly. But them this motor would not run in 03 mode.
    Have you compared the 08 mode values for web advance to the default? =^..^=
    • cpjim
      • May 2015
      • 47
      after 24 hours and a couple of re-boots the stupid thing is working ok now..
        • 23007
        That sounds like a "6" series. All it needs to be complete is E010 jams. =^..^=
