estudio 6540c locks up, reboots
  • tnrtt
    • 156
    I have a 6540 I brought in to the shop. I'll send a print job, the data light will go solid green. Then the panel locks and then it reboots. Any ideas before I start throwing parts at it?
    • 23010
    Re: estudio 6540c locks up, reboots
    Is there a department code set up? =^..^=
    • tnrtt
      • 156
      Thanks for the reply BC. No department codes set up. It has also locked up on me exiting the UI. It seems to also happen more often printing larger files. The data light will blink for a while then go solid green, then the panel locks up and reboots about 45 seconds later. I erased, formatted the HD and loaded current firmware. Same problem. At the end of the day I took another ADI-HDD from a known good 5540 and got an F106-5 code. Will 3C it when I get in in the morning. Other manufacturers I have worked on, a bad HD causes weird problems including rebooting.
        • 23010
        Originally posted by tnrtt
        ... Other manufacturers I have worked on, a bad HD causes weird problems including rebooting.
        Yes Konica Minoltas will do that when the HDD won't spin up. It's a good place to start. =^..^=
        • arnh79
          • 469
          And just as a reminder, you can't swap HDD's from another machine with that series. They have the Wipe technology on them so only a brand new HDD will work. That's why you got the F106 error. It makes the troubleshooting process costly if it turns out not to be the HDD but that's all part of the fun when working on eBX Toshiba's!
          Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
          • tnrtt
            • 156
            Really arnh79? I formatted the HD and loaded firmware and it appears to be working fine. Will run it as the office copier for several days to see if my issue is resolved.
            • arnh79
              • 469
              That's good news! Maybe US region sells regular HDD? Up North we're stuck with the proprietary single-machine HDD's. Glad you got it sorted out.
              • tnrtt
                • 156
                I just looked at TSB-1134 on FYI arnh79. There's a serial number cutoff. Looks like the newer machines require a new HD.
