Stop copying when User reach limit on Toshiba e755
  • kazihaha
    • 100
    [Misc] Stop copying when User reach limit on Toshiba e755
    Hi Techs,
    I'm using Toshiba e755
    How can I stop copying process IMMEDIATELY when user reach the limit.
    I set limit "10" for user A.
    User A used 9.
    And now user choose to make a 100 copying, the machine will did it all even 99 over copying, so the quota for user is over 99 copying.
    How can I stop this process when user reach the limit?
    It a bug?
    Please help me this.
    https://sieuthithietbivanphong.com
  • NSD
    • Aug 2011
    • 44
    Re: Stop copying when User reach limit on Toshiba e755
    Have a look in the manuals for zero stop. I am not sure if it can be done but i would search around that phrase.
    Sent from my SM-G920F using Tapatalk
    • kazihaha
      • 100
      So the solution for me?
        • 23009
        Read The Fricking Manual, RTFM.
        Always an excellent place to start. =^..^=
        • kazihaha
          • 100
          The manual does not mention this bug
            • 23009
            Page 186 has a few words on the topic. In short, it cannot stop immediately, so a few more pages will be printed. See here:
            • NeoMatrix
              Senior Tech.
              • 3513
              Sorry I don't work on this machine.
              Curious....:
              How is the print limitation (page186) enforced when the MFD starts a print job with department limitation set to 100 pages and the user prints a 200page document ?Is the 200 page print job finished entirely, or only runs up to the user fixed limitation then stops after clearing 2-3 blank pages inside the MFD ?
              • kazihaha
                • 100
                Curious....:
                It'll print all 200 pages, it's a bug.
                • kazihaha
                  • 100
                  So If user have 1 left and know this bug, they will make a copy of many and many Ex: 9999
                    • 23009
                    Curious....:
                    Excellent question. None of my endusers use Limitations, so it's never come up for me. =^..^=
                    • NeoMatrix
                      Senior Tech.
                      • 3513
                      Odd...
                      There must be something wrong with the MFD setup. Is individual user authentication turned on with this machine? Does the PC-User have to enter a their own personal password/ID-code when they used the copier or press the software print button ?
                      If I get time I will RTFM...
                      ---- update ----
                      I had a quick RTFM. Local Authentication is setup using the TopAccess guide... I assume the TopAccess guide is in a separate secure PDF.
                      • kazihaha
                        • 100
                        Odd...
                        ---- update ----
                        My user have to enter Username and Password to log on. I'll test a gain, yesterday it printed out 5 pages over the limit.
                        • kazihaha
                          • 100
                          Odd...
                          ---- update ----
                          It worked like you said. Thanks so much.
