Toshiba e studio 4520 bottom tray unit is not working
  • harisjameelpk
    • Feb 2015
    • 23
    It shows that paper jam when I want to print from bottom tray which is single big tray it shows paper jam but check there is no paper I change whole bottom tray section now the new bottom tray is making sound and already check bottom tray but it is working on other machines what should I do ?
    Sent from my 0PJA10 using Tapatalk
    • 23009
    Re: Toshiba e studio 4520 bottom tray unit is not working
    Is there any paper behind the tray? =^..^=
    • harisjameelpk
      • Feb 2015
      • 23
      No paper behind the tray I checked it
        • 23009
        Did you do anything else? =^..^=
        • harisjameelpk
          • Feb 2015
          • 23
          I change whole bottom unit What you reckon?
          • Mad_Coachman
            • 99
            Check the electrical interface for damaged contacts.
            • harisjameelpk
              • Feb 2015
              • 23
              In bottom tray unit ?
              • Mad_Coachman
                • 99
                [QUOTE=harisjameelpk;529952]In bottom tray unit ?
                I'm sorry...I thought you had the big tray that holds 5 reams of paper.
                • harisjameelpk
                  • Feb 2015
                  • 23
                  [QUOTE=Mad_Coachman;530003]
                  Yes I have that tray too but still same problem
                    • 23009
                    I think the Mad Coachman might be referring to the modular connector for the drawer. A persistent enduser can cram paper into the connector. It can be hard to see the paper bits crammed into the connector.
                    If you do find paper bits, turn the MFP Off before fishing around with your dental picks. It's so disappointing to discover the problem, then to blow the LCT controller in the process of fishing out the bits of paper.
                    Other possible things to watch for are the plastic alignment pin where the feed unit mates with the rear frame. The rear of the feed unit will be floppy, and the gear drive disengage.
                    Another common thing is for the last tech to install the bushings in the LCT drive unit backwards, so the gear drive can disengage. The bushings must be installed from the inside of the drive pack, no the outside. Also check that the wiring has not been damaged, by the clutches spinning and yanking on the wire harness.
                    • harisjameelpk
                      • Feb 2015
                      • 23
                      Thanks for help I will let you know what happen
                      • Iowatech
                        Not a service manager
                        • 3930
                        So you replaced the entire frame that contains that drawer or just the drawer?
                        And when you say there is no paper, is there no paper jammed in the machine or is there no paper in that drawer?
                        Sorry, but a lot of us including me specifically are not good at foreign languages and important concepts can get lost in translation unless the correct questions are asked.
                        Personally, I'd be looking for a broken or stuck sensor feeler in the feed area, or worn rollers (take a look at the regular drawers that work for guidance), but that is probably nonsense as the last Toshiba equipment I worked on was analog.
                        • harisjameelpk
                          • Feb 2015
                          • 23
                          No worries it's OK
                          The problem is bottom big tray is showing paper jam but there is no paper on side yes papers are in tray but I change bottom tray with another one but it's still have a problem I change the sensor after that motor sound krr krr sound comes one thing I notice that when it shows paper jam and I open drawer the tray is not up and when second problem came I saw the paper tray was up you know the black one inside the drawer
                          • Mad_Coachman
                            • 99
                            Please tell us the jam code so that we can help you solve this. Or does it just tell you to check the tray?
                            • harisjameelpk
                              • Feb 2015
                              • 23
                              I fixed the problem the problem was with the cable which we attach the bottom tray with machine that was faulty I put new now it's working
                              Thank guys for your comments
