User Pin
+ More Options
Posts
  • venluckey
    • 36
    [Misc] User Pin
    I work for a company that takes off lease copiers and wipes/formats the hard drives and tests them for resale.
    Have a E-studio 4540c that asks for a user pin. Got in to administrator mode using the user/password method. Did a Factory reset, per our company policy.
    Now we get 4 dots that scrolls right, then a grey box with a ?. Did i somehow erase some firmware/software?
    I first tried setting the 9120 and 9122 to 0, but they were already 0, no help.
    This is the first machine we have seen like this.
    Any insights?
    And does anyone have some 4 digit 08 codes? I seem to have trouble finding a table of them for this machine.
    • 23006
    Re: User Pin
    It sounds like this MFP has Papercut installed. Did you do a 3C-3, 3C-8, mode 49 firmware load, 08-9030 firmware initialize? =^..^=
    • sdrawkcab
      Confused & Bewildered
      • Jun 2009
      • 317
      Re: User Pin
      Try 08 - 9132 set to 0
      EWB back to copy screen
      Some days, it's just not worth chewing through the restraints
      • venluckey
        • 36
        Re: User Pin
        Our company does not have access to firmware downloads. I will try the code listed, I have disabled papercut before using the apps menu. Did not see it this time.
        Can someone provide a list of Service codes that you find the most helpful:
        Ones i have are:
        690- HDD Format
        257- Counter
        400- Reset Trouble (0) means set to 0
        202- Disable external Key Counter
        600- Disable user Access
        263- Reset Admin Password
        629- Disable user Access (0)
        9120 and 9122- Reset User access (0)
        692- Adjust Screen
        8929- Reset Admin Password
        I know some are old, and mixed models. I don't really work on Toshiba's so I was given these notes from another Tech from "Discovery" of codes on forums. What i was looking for was maybe a better way of understanding codes. Does toshiba have sub catergories for codes, such as 600 range is User access related, and so on?
