E-Studio 356SE Hang-Up/Freeze
  • noobie1
    • Jun 2015
    • 48
    [Misc] E-Studio 356SE Hang-Up/Freeze
    Hi,
    I need some help to figure out what is the wrong and problem of my Toshiba E-Studio 356Se Machine. In time turning power on the machine, the machine display in the panel "Checking HDD" after 15-20 minutes past it getting hang-up and freeze. I try to press any button on the control panel doesn't work. Please i need some information or could help what went wrong on my machine? what should i do rectify this problem.
  • riyadh hossainbd
    • Dec 2015
    • 239
    Re: E-Studio 356SE Hang-Up/Freeze
    Originally posted by noobie1
    Hi,
    c+3 > clear hdd if it will ok then reinstall firmware otherwise change hdd and reinstall firmware
      • 23009
      x2
      You're seeing the early stages of HDD failure. Get yourself a Wipe Drive. =^..^=
