08 code for es 256
  • austek
    • 4
    [Misc] 08 code for es 256
    Hi there, I need to erase the hdd on an estudio 256. Does anyone know the 08 code for this. It used to be 690 on earlier models. Thankyou.
  • laitang
    • Nov 2012
    • 627
    Re: 08 code for es 256
    Initializes HDD:
    [5] + [C] + [POWER] -> 3 -> start -> 1
      • 23009
      If all you do is wipe the HDD you will leave the machine as a brick. Are you sure that's what you want? =^..^=
      • austek
        • 4
        Sorry, should of said initialise. Thanks for you help laitang. Problem solved.
        • clint@clintsimonsen.com
          • 125
          Just use factory reset in the admin menu
          Sent from my Nexus 5 using Tapatalk
