Toshiba E-Studio 281 c
  • Orion2010
    • Jun 2015
    • 176
    [Jamming] Toshiba E-Studio 281 c
    I have e problem with Toshiba e -studio 281 c.
    In the first tray the paper stuck during the process of printing but from the other trays the process of printing is ok.
    I have cleaned pick up, and also changed it to all block pick up but i have the same problem..
    What can I do next?Do you have any suggestion?IMG-20161223-WA0004.jpgIMG-20161223-WA0005.jpgIMG-20161223-WA0006.jpg
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: Toshiba E-Studio 281 c
    Never worked on a ES281 if they're anything like the ES165-205
    you may like to check the feed solenoid contact pad has not turned sticky like chewing gum.
    If so remove the old contact pad and replace with a new one.
    You ""MUST"" replace the contact pad otherwise the solenoid will continue to hold the plunger down as if it was magnetised.
    Replace the solenoid contact pad.
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      Looks like the front and rear paper guides are either not touching paper or they are broken and not centered in the paper tray.
