C440 Toshiba ES356se
  • noobie1
    • Jun 2015
    • 48
    [Error Code] C440 Toshiba ES356se
    Looking best advice to all expert technicain in toshiba. I encountered error c440 in the Toshiba ES356se ,i tried reset the error in the machine but still coming the error. How to get rid off this error? Please give me best solution of the error C440?
  • toshibaestudio
    • Jun 2016
    • 116
    Re: C440 Toshiba ES356se
    1. Fuser themistor
    2. Heater lamp
    3. Burn marks
      • 22999
      I think that i would start by checking the electrical components in the fuser. A reset only works when all the electrical fuser components are intact. =^..^=
      • onlineprofitinternetshop
        • 17
        Fuser problem.., especially the termistor..., concentrate on it and check everything is there is cut wires .,
        • ramakrishna j
          • Jan 2017
          • 5
          try to reset with code 08-400 value to 0. if not solved. try to clean the main thermostat, the problem while solve obviously.
