Are 2050c and 2555cse developer-unit the same?
  • Mortytech
    • Jul 2025
    Hi,
    I am having a problem with a developer-unit from a 2555cse, but I have a developer-unit from a 2050c in disposal.
    So I was wondering if those two are the same? And if it's possible to just put the 2050c unit directly in the 2555cse?
    Best regards
    Morten
    Re: Are 2050c and 2555cse developer-unit the same?
    Originally posted by Mortytech
    Hi,
    Best regards
    Morten
    have you compared the part numbers in both parts manuals?
      • 23003
      Nope. Different part numbers. =^..^=
      • Blizzoo
        • Aug 2013
        • 608
        Swap the dev's front covers (the one you see when the dev is inside in the machine) between them an then will fit.
