Hello guys im have a problem on this model it always have a jam problem i replace separation roller clean all sensors on pick up assembly. Replace clucht and still unsolve. Please any body have a solution on this thanks.
Toshiba estudio 305 casset 2 jam problem
Re: Toshiba estudio 305 casset 2 jam problem
Ordinarily I won't go guessing about jam codes, but this looks a bit like E130/C130 jams. Look at the sector gear on the back of the tray. Manually drive the lift plate up to confirm that the lift plate is high enough, before the sector gear touches the side rail. If you're still not getting enough lift, even with an uncracked sector gear, and the screw tight, you can add a bit of bend to the lift plate to get some additional height.
What jam codes? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Thanks for the help guys. I found the cause of jam its the mylar that block the actuator to return to position and cause jam. See my attachement i just cut some part of the mylar.Attached Filesthere is no glory without sacrificeComment
