Toshiba studio 757 blanks
  • Fattdaddy
    • Aug 2012
    • 38
    Machine received a power surge and took out the HDD. Error F101-4 Tried recovery,didn't work. Replaced HDD and firmware. Installation went fine but, when trying to print gamma adj. pattern - blanks. Copies are blank. I can print a grid test pattern in 04 mode but that's it. Need any suggestions.
    • 23007
    Re: Toshiba studio 757 blanks
    System Board first, then Logic Board. Also possible SRAM. Replace them only one at a time though. Two or more at a time can be catastrophic.
    • Fattdaddy
      • Aug 2012
      • 38
      Going out Mon. to install sys and/or lgc. Would u start with sys bd.? Have the manual and it talks about "return license". Can you give me some guidance with that?
        • 23007
        The Logic board is always simpler to change, as you can see.
        For the System board you can use 3C-5 Key Backup Restore (SRAM to FROM). See page 350 of the SM. If you read the description notes, on page 914 it says: [A] Return License, Notes: If the Setting Mode (08) is not started up. "[A] Return License" can be omitted.
        Omit [A] =^..^=
        • Fattdaddy
          • Aug 2012
          • 38
          Well that did not go well.
          Installed logic and got update errors . 00 code which just means "other error" After talking with Hytec tech service we went ahead and put in the system board and went to update and now I can't enter the update method 1,2 or three. No response from keys but I can enter the update mode with 4+9. If you have any suggestions, I need big help.
            • 23007
            Can you go back to new LGC + old SYS, and the SYS installation procedure? =^..^=
              • 23007
              Did you install the new SYS board with the old SRAM? Preferably yes. One at a time. =^..^=
              • Fattdaddy
                • Aug 2012
                • 38
                Nope Cant get to update
                • Fattdaddy
                  • Aug 2012
                  • 38
                  Yes on new Sys and old SRAM One at a time?
                    • 23007
                    You can still try old SYS with new SRAM. That's about all I've got.
                    Here's the theory: Machine data are stored in three locations. If the machine can identify two like batches of data it can update the third to be the same. It the machine identifies three different batches of data it is confounded, can't decide what to do. So always change only one of these three data sources at a time, and complete the installation procedure before moving onto the next possibility.
                    That being said, you may have passed beyond the point of no return. =^..^=
                    • Fattdaddy
                      • Aug 2012
                      • 38
                      I just have the old SRAM. If I order a new one would it be programmed as I cant copy any info. What would you do at the point of no return?
                        • 23007
                        1) Bring in your Toshiba service rep. Maybe he's got some magic we haven't touched on yet.
                        2) Bring in your service manager and sales rep, to get that box out of the field.
                        • Fattdaddy
                          • Aug 2012
                          • 38
                          Not really an option. I'm an indie out here.Jeez I thought you were the Toshiba tech. lol Thanks for all you thoughts. If anything comes to mind please let me know.
                            • 23007
                            Multiple board replacements get very tricky with Konica Minolta and Toshiba. All the boards on the machine are "married" to each other, and cannot be swapped around (with a very few exceptions). Sorry I couldn't be of more assistance. =^..^=
