Code: Alignment for toshiba copiers e 720
  • toshibae720
    • Jun 2025
    Please code Alignment for toshiba copiers e 720
    Left
    Righ
    top
    Bottom
    Code: Alignment ADF e 720
    Thanks you
  • thanhduong1986
    • Apr 2017
    • 13
    Re: Code: Alignment for toshiba copiers e 720
    05-305.306
    adf 357,358,365,366
      • 22999
      I believe this is covered well in the service manual. I hope you plan to align the print functions first, Then the scan functions second, then the DF functions third. If you do it in another order you'll find that you need to keep repeating the same adjustments again and again.
      Get a service manual. =^..^=
